10-23-2019
04:14
10:03
LizzyFitbit
10-23-2019
04:14
10:03
LizzyFitbit
The screen on my Fitbit Versa is blank, it’s still charging, syncing and rewarding my steps and pulse but nothing at all on the screen, I have tried holding the buttons for a restart, but it is still blank
Hello and welcome to the Fitbit Community @Marharmonie
Im sorry to see your Fitbit Tracker has a blank screen but I am happy to see that you are still getting credit for your activities. Now let’s get that display working again...I did see that you tried restarting your Fitbit Versa which is great. Sometimes it helps to perform a restart several times. Please try restarting several times to see if that doesn’t get your display working again.
Hers how:
You may also want to clean the contacts of your Versa as well. Please look here to find the proper way to keep those contacts clean: https://help.fitbit.com/articles/en_US/Help_article/2005/?q=Clean&l=en_US&fs=Search&pn=1
😃 Please let me know if does indeed resolve your issue and gets you back up and running again
Hi, I’ve tried re-starting several times but the screen is still blank
Best AnswerHello again @Marharmonie
Im sorry that restarting your Fitbit Versa several times did not resolve your issue. At this point the only suggestion I can give is to call a Fitbit Customer Service. You can find ways to contact them here: https://help.fitbit.com/?l=en_US&cu=1&fs=ContactUs&co=GB
I'm really sorry I couldn’t have been more help.
Hi @Marharmonie. Welcome on board. @SunsetRunner, thanks for your big help!
@Marharmonie, thanks for your efforts while trying the restart process. Before getting in touch with our team, please try to perform a factory reset on your Versa to get the screen responding. After this process you'll need to reinstall your apps and clock faces after this process, so make sure to sync with the Fitbit app prior doing this. Here are the steps:
If this process works, please set up your Versa as a new device in the Fitbit app and continue using it to records your stats.
Keep me posted!
