My screen lights up and sends me notifications, but when I try to select the notification, or swipe up to see my daily steps it doesn’t respond. It also won’t respond when I swipe right to see apps. Screen not responding to touch at all
Best AnswerTry restarting the Versa several times. If it is still not swiping do a factory reset. If it is still not swiping you will need to conyact Support (link in my signature)
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
09-24-2018
04:37
07:45
09-24-2018
04:37
07:45
Welcome to the Forums @Ajohnson0426 and @NellyG thanks for stopping by.
I would like to know if the instructions provided by our friend worked? Are you still having issues with your Versa touchscreen?
Hope to hear from you soon. ![]()
