01-20-2019 01:29
01-20-2019 01:29
Woke up this morning to Green vertical lines over my screen. Functionality behind is just about visible but lines look like something out of the matrix. Really annoyed as upgraded from the charge 2 that never had problems to this, always having notification connectivity problems and now this. Watch is 5 weeks old and outside of fault return period for curry's UK! Have reset watch several times as suggested but problem remains with screen.
08-11-2019 00:10 - edited 08-11-2019 00:14
none of the solutions worked for me. ..on my 2nd replacement ... still having same issues.
was a big mistake moving from garmin to fitbit.
googling fitbit vertical lines i was shocked to see so many folks having the same issue.
for a $249+ product this is a lemon. it looks like versa is hastily bought to market product with not enough design/engineering or testing done . their share price speaks for itself..sadly i am bag holder there losing a lot of money as well.. 😞
FITBIT..are you really kidding ??
04-04-2020 22:57
04-04-2020 22:57
Same problem. I've reached out to customer support, it may be a week! I might just get a new one this one is less than a year old!
04-05-2020 04:55
04-05-2020 04:55
I've also been having this issue. I did the factory reset and still have lines. I'm unable to change clock faces because my screen only shows vertical lines
06-17-2020 07:11
06-17-2020 07:11
I am having the same issue. For the cost, I would hope that my device would last much longer than a few months. This is my 3rd Fitbit watch over 5 years. Each version hasn't last. Replacements of the 2 previous version didn't last long either. Quite disappointed as I have loved my Fitbit watches, yet the product just lasts. I have left my watch on the charger over night, just for the watch to turn completely off as if the battery is dead. The face is pixelated with vertical lines upon it when it does come on. I received it for my birthday from my teen daughter. She purchased additional protective face covers for the watch, of which I have constantly used since it was purchased. I have tried factory resetthing the watch several times, even per the suggestions of this post. I am quite disappointed and dissatisfied with the failed hope of this brand of watch not working, especially considering I want to like this company's product so badly.
06-17-2020 19:43
06-17-2020 19:43
Unfortunately, I am having the same problems. Mine is 2 & 1/2 years old. I would like advice on comparisons of smart watches, as this is the only one I have ever owned, and I am the type to try a variety. Any recommendations? Thanks!
06-17-2020 21:09
06-17-2020 21:09
07-29-2020 23:57
07-29-2020 23:57
You can try fit it or upgrade i like my new versa 2 cuz no problem it probably you wear too much you have keep charging all day so when I got my new versa 2 I only let it go to 70 or % then charger till 100% morning and when I go bed plus I like it has Alexa and other app I i only got one clock face cuz I don't want over run it and no problem the other one keep shut off when I do my exercise
08-09-2020 16:51
08-09-2020 16:51
Mine did the same and they say it can’t be fixed. They will give me a discount for a new one but for the money it cost I would have expected it to last longer than 2 years. Very frustrated. Especially because I lost my job because of covid and can’t afford a new one!😕
08-11-2020 15:58
08-11-2020 15:58
I am seeing the same thing. However I can hold those buttons for 3 days and nothing, no vibration. THoughts?
08-11-2020 20:04
08-11-2020 20:04
I had to hold the three when the Fitbit logo came up release the bottom button I think but double check me then hold it for like 12 seconds then
It vibrates release all buttons then it takes a long time like 5 min to go on and off several times before it’s done. But call the service people they can help. And check your warranty.
10-26-2020 23:27
10-26-2020 23:27
I’ve done this multiple times now and still no luck. I think I’m way out of warranty. Can anything be done? I got it used from my sister when she upgraded.
10-27-2020 05:07
10-27-2020 05:07
And following the factory reset, the watch no longer turns on!!!
10-28-2020 09:17
10-28-2020 09:17
I agree with you. For the cost, I would think it would last longer.
01-01-2022
17:41
12:59
DavideFitbit
01-01-2022
17:41
12:59
DavideFitbit
Smart decision!
Same thing happened to me.. Versa 2 are garbage
01-02-2022 12:10
01-02-2022 12:10
Mine is the same, but when I try three button reset the Fitbit logo does not show up. When charging it doesn’t say so, and if it turns on by amazing luck, it will say good charge, so not a charging issue. What do I do! Driving me crazy!!!
01-02-2022
12:14
16:46
DavideFitbit
01-02-2022
12:14
16:46
DavideFitbit
Unless it is still under warranty you are screwed. Fitbit will not service it. Good luck! I threw mine in the garbage and bought an Apple.
If it is out of warrant Fitbit will not help you! I threw mine in the Garbage and bought an Apple.
09-04-2022 03:29
09-04-2022 03:29
I have the same issue and this solution did not help my problem. This is my 4th Versa and I think it is time to switch to Apple watch!
09-10-2022 14:44
09-10-2022 14:44
Ditto
within the warranty I had a problem with the Versa 2. Now I’ve got the green screen AND it’s out of warranty.
It’s so annoying that the Fitbit has such a short life. I’ve been sent a 35% discount code … I won’t be buying another Fitbit
09-10-2022 15:38
10-16-2022 23:59
10-16-2022 23:59
can i have the code? 😂
