02-28-2019
12:52
10:54
02-28-2019
12:52
10:54
I have a two month old Fitbit Versa and today the screen is just blank. It’s fully charged (I checked via the app) I’ve tried holding the buttons down as suggested on other posts but nothing really happens, the screen faintly lights up but there are no images.
Can anyone suggest anything else that I can try?
Best Answer@DawnH71 Try performing a 3-button factory reset. If this does not help, you will need to contact Customer Support:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
Best AnswerSo frustrating. Did a full charge at 9pm and by 6am it was half battery. Still nothing on the screen.
Welcome on board @DawnH71 and @Tbentn2! Sorry to hear about the issues you're having with your Versa watches. I really appreciate your efforts and time while troubleshooting them. Nice way to go!
I was about to create a support case on your behalf, but I saw that you both have already contacted our Customer Support Team.
Great to hear you're in good hands now!
Thanks a lot for all your help @Marrrmaduke!
I'll be around if you need further assistance!
@MarreFitbit Thank you so much for such a prompt response! 😄 Good luck, @DawnH71 @Tbentn2 !
Thanks to you for all your help @Marrrmaduke!
We're glad to have you always around!
