08-12-2020
14:42
14:39
08-12-2020
14:42
14:39
The screen on my Versa is flickering and only showing a partial screen. I can not even get to the settings app to try a factory reset. Any ideas how to fix it?
Hi there @Cicant, welcome to the Community Forums. Thanks for the details provided in your post about your Versa's screen behavior. I appreciate you've taken the time to try fixing it.
I've seen that you contacted our Support Team after posting here and they tried helping you with the screen issue. If you have any questions about the resolution of your case, feel free to contacted them back for further explanation or you can check our warranty policies here for a better understanding of the information they provided to you.
