06-06-2019 05:05 - last edited on 06-07-2019 16:09 by LiliyaFitbit
First noticed an issue when it stopped tracking sleep yesterday, thought I slept weird so it didn’t track. Then this morning, I saw it didn’t track again. Restarted device using buttons, now the screen won’t transition. Everything I have seen here says to shut it down going to settings on watch, but I can’t because the screen won’t move! Help
Welcome to the Fitbit Community @Sassy74!
Thank you for your troubleshooting efforts to reset your device in order to resolve the issue with tracking your sleep. Please confirm if these are the steps you tried to restart your watch: How do I restart my Fitbit device?
If the watch still shows the same behavior after the restart, you can try a factory reset. Please note that after doing a factory reset, all apps and music installed and the data that has not synced to your account will be deleted. In order to do the factory reset, please do the following:
Once the Fitbit.com/setup screen appears, open the Bluetooth settings on your phone and unpair the watch from the list. Then, please set up the watch back to your account with the instructions on this link: How do I set up my Fitbit device?
If you receive an error message such as "Data not cleared, sync and try again" or a red X mark, please continue with the set up as detailed above.
You can manually log sleep to reflect the time slept by following the instructions in How do I change my sleep history?
Let me know how it goes.
Best AnswerHi @Sassy74 , thank you for your reply. I am sorry for the delayed response.
Thank you for the update. Since your device completely died, I've gone ahead and escalated your case to our Support team, for them to assist you further. Please keep an eye on your inbox for further instructions.
Best AnswerI had this same issue and did the factory reset (three button hold, release after logo, etc.). After setting up my Versa again, it is now stuck on the Quick Tips screen because it won’t let me tap on Start. I tried the factory reset again and it’s still the same, no touch screen recognition at all.
