06-22-2020
05:01
07:39
06-22-2020
05:01
07:39
On Saturday I went to bed with my versa working just fine and a full battery (I had just put it back on from charging it). When I woke up, the screen will not turn on no matter what I do. At first it was still syncing and tracking because I could see my steps, etc. when I opened the app on my phone. But, now it isn't syncing or tracking. When I open the app and try to sync it says "device not found." I've tried doing a factory reset, still no logo appears and it doesn't vibrate to show me it's resetting either. I'm not sure what else to try or what to do from here. Help!
06-22-2020 07:42 - edited 12-29-2023 05:31
Hi there @Kaytclick, welcome to the Community Forums. Thanks for the details provided in your post about your Versa's screen behavior and for taking the time to fix it prior to posting here.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
Let me know how it goes, I'll be around and glad to continue assisting you with this.
Best Answer06-22-2020 07:59
06-22-2020 07:59
06-22-2020 08:28 - edited 09-30-2023 05:30
Hi there @Kaytclick, thanks for getting back. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
Best Answer06-22-2020 12:02
06-22-2020 12:02
Best Answer06-22-2020 12:27
06-22-2020 12:27
You're welcome @Kaytclick!
