01-25-2021
02:54
06:08
01-25-2021
02:54
06:08
My Versa watch suddenly stopped displaying anything. I have charged it, tried resetting it several times and even tried to do a factory reset but nothing appears. It still vibrates and is syncing with my phone but can’t get anything at all on the screen. The Fitbit display doesn’t even come on when trying to reset it, nor does the charging icon come on when plugged in.
01-25-2021 06:09 - edited 02-26-2024 03:37
Hi there @LesBfit, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
Since your Versa is still syncing, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer01-25-2021 07:51
01-25-2021 07:51
Yes I’ve tried this as well and it doesn’t fix it. Any other suggestions?
Best Answer01-25-2021 09:23 - edited 08-31-2023 05:28
@LesBfit I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
