12-05-2018 07:43
12-05-2018 07:43
Hello! I have had the Versa for approximately a week and have noticed the sensitivity isn't strong enough... when I turn my arm to see the time, it doesn't always reply. Sometimes it does, sometimes I have to over-dramatically twist my arm before it lights up. When I receive a phone call, it rings but stays blank till I hit the left button... I'm coming from a Pebble which I LOVED and didn't have these issues. I could simply, shake my arm and the time would pop up... the Versa seems to take much more effort???
Best Answer12-05-2018 08:27
12-05-2018 08:27
Hi, did you set your screen to be automatically activated? You can find this setting by press and hold for a few seconds the left button. My Versa reacts on the slighest movement of my wrist. Kindest regards, kuzibri
12-05-2018 09:24
12-05-2018 09:24
It is set to auto... guessing it's just not on it's game... thank you for the try!
12-05-2018 09:26
12-05-2018 09:26
You're welcome, sorry it did not solve your problem. Kindest regards, kuzibri
Best Answer12-05-2018 09:54
12-05-2018 09:54
@Mel4Bama coming from thr pebble in assuming that your use to what I've been told is a wrist flick.
Fitbit does it differently and uses a simple 90° rotation of the wrist while the forearm is somewhat level. For me it seems the arm needs to be within 39° of horizontal, then rotate the wrist. No flicking but a smith rotation that can be done pretty slow.
12-05-2018 10:58
12-05-2018 10:58
Best Answer12-05-2018 12:25
12-05-2018 12:25
Normally the tracker does not light up with notifications but waited for the arm to be rotated.
I believe there is a setting under the notification setting to change this with the Versa, but can not confirm until I reconnect the Versa to my account.
12-05-2018 14:57
12-05-2018 14:57
As far as I know, cause my Versa lights up when a notification comes in, there is need to move your wrist. Go to settings - notifications - set them on (either during daytime or night or both) and reboot your Versa by holding the left and lower right button pressed untill it shutsdown. After a minute or so, turn it it back on by pressing the left button. Hope this helps, kindest regards, kuzibri
