04-16-2018 18:21
04-16-2018 18:21
My versa is taking FOREVER to set up, it has already been over 4 hours and I am missing all my steps 😞
04-16-2018 18:33
04-16-2018 18:33
Hm, mine took 40 minutes, watched it the whole time although it updated twice. Found that kinda weird but it didn't take too long the second time. Try restarting the Fitbit App and charging your Versa.
Want Spotify for Versa? Click Here to Vote!
Click Here to Vote for Low Power Mode!
Best Answer04-16-2018 18:44
04-16-2018 18:44
I am going on 3 hours WTH !!!!! Did you find out why? TIA
04-17-2018 02:14
04-17-2018 02:14
Setting up my Versa took about 30 minutes via the app on my iPhone. The download takes probably 20 minutes of that, it then installs with the Versa restarting a couple of times. It seemed to pause a minute or two on the Fitbit logo with a green screen but finished OK.
The download speed will be dependent on your Internet connection, moving the Versa and device you are using the FitBit app on closer to your router may help with WiFi connection speed.
Best Answer04-17-2018 15:00
04-17-2018 15:00
@TempestFire Everything you said sounds familiar especially the green screen. I used really crappy wifi and it only took 40 minutes. I don't know my house wifi password so I used my mom's which was at the smallest circle thing. So far, nothing seems to be broken or breaking. Hopefully, everyone's Fitbit will start working soon!!😃
04-17-2018 17:44
04-17-2018 17:44
I finally was able to update via WiFi. Bluetooth after two days was impossible at a snail's pace.
I switched my router to 2.4 GHz band, seems the Versa/Fitbit can't do 5 GHz.
Removed my screen timeout on my phone, left it on update screen.
Download took 20-30 minutes, installation a few minutes, and prior to sync completion my Versa was ready to go.
05-02-2018 19:54
05-02-2018 19:54
Supposedly WiFi setup is faster but that option failed multiple times. I opened a chat session with support and they said wi-fi the way to go but forum posts suggest others had same problem I had. Support said blue tooth update would be about 6 hours but I am 8 hours in and by status bar I think I have 8 hours to go. Please let everyone know method you were using to update firmware WI-fi vs Bluetooth. I am betting most of us are forced to use Bluetooth despite support saying WI-fi is possible and faster. Per support a wi-fi update of firmware would be ~30 minutes.
11-01-2018 01:06
11-01-2018 01:06
After multiple failed attempts to use WiFi to update/install on a new Versa, I defaulted to Bluetooth and it's working - very slowly, but surely. Elapsed time currently 2 hours, guessing another hour to completion.
Best Answer11-27-2018 02:46
11-27-2018 02:46
mine is taking over 2 hours to set up and it is only 50% done.
12-08-2018 11:35
12-08-2018 11:35
I just got mine yesterday and charged it today but the download is also taking way to long. I'm hoping this is normal. I had no idea it would take this long.
Best Answer12-10-2018 10:43
12-10-2018 10:43
@alexandrafabyo @MsPittsburgh Welcome to our Fitbit Community! I'm sorry to hear about the setup experience you've had with your Versa trackers. I would like to follow up and would like to know if they could be set up or if they're unable to get set up on your accounts.
I appreciate your patience with this.
Looking forward to your responses! ![]()
11:30
03:56
JuanJoFitbit
12-10-2018
11:30
03:56
JuanJoFitbit
Thank You! I took someone's advice on here and turned off WiFi and turned it back on and left both my phone & Fitbit out in the hall as close to router as I could get. (Both plugged in & charging) Then I went to bed. When I got up in the morning & looked at my phone my Versa was connected. All I had to do was press Done. Thankfully I got it working. I also deleted my Charge 2 account. Not sure if that had anything to do with it or not! Thank you for checking in and following up!
Moderator edit: format
12-11-2018 03:59
12-11-2018 03:59
@MsPittsburgh I'm so glad to hear that you managed to get your Versa set up. Thank you for posting the update here!
I'd like to invite you to visit our Discussions board, where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community! ![]()
Best Answer12-14-2018 08:57
12-14-2018 08:57
Since setting it up though, it is not tracking my sleep, This morning it said 1 hr. and a half. which I know for a fact is wrong. I never had this problem not once with the Charge 2. I don't know what to do other than return it.
Best Answer12-15-2018 08:02
12-15-2018 08:02
@MsPittsburgh Thank you for getting back! Let me go ahead and find a solution for you. Please try restarting your tracker as described in this help article. After this, make sure that you are not wearing your Versa too tight. Finally, monitor your sleep tracking the following nights and see if the issue gets fixed.
Keep me posted on the outcome! ![]()
08:31
04:27
JuanJoFitbit
12-15-2018
08:31
04:27
JuanJoFitbit
What I tried last night was I set my Versa on "Sensitive" and this morning.....voila! That worked; It showed that I got over 8 hrs. sleep; Thanks for your help. I would suggest to others to do the same if they are having problems re: sleep tracking.
Best Answer12-17-2018 01:43
12-17-2018 01:43
Best Answer12-18-2018 04:32
12-18-2018 04:32
@MsPittsburgh I'm so glad to hear that your Versa is tracking your sleep accurately now. Thank you for posting the update here. Have you heard about our Discussions board? In this board, you'll be able to tell your stories, meet more people and start your own topics.
@alexandrafabyo Thank you for getting back! In order to assist you accordingly, please let me know if you are experiencing setup issues with your Versa or if your tracker is not tracking sleep properly.
See you later! ![]()
Best Answer12-18-2018 09:54
12-18-2018 09:54
no more problems with setting up my Versa. all good now. many thanks
Best Answer12-19-2018 04:47
12-19-2018 04:47
@alexandrafabyo I'm so glad to hear that your Versa is working properly now. Than you for posting the update here.
I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! ![]()
