10-09-2018
12:31
06:33
AlejandraFitbit
10-09-2018
12:31
06:33
AlejandraFitbit
I received a new Versa from Fitbit because my other one broke... When I am setting it up I get stuck on the "enter the number on your Versa display." I enter the number and it says "connecting to Fitbit" and does not move past this screen. Have tried resetting, updating phone/app, deleting app... etc. Any help would be awesome!
10-09-2018 14:23
10-09-2018 14:23
I would try force closing the app that you are using to sync the Versa to. You will lose all progress in the setup process but it should help unfreeze your screen and hopefully move on. Mine has done that the last few times when I tried switching from my Versa to Ionic or vice-versa.
one cruise ship at a time!
10-10-2018
06:35
08:01
10-10-2018
06:35
08:01
A warm welcome to the Community @R0W and @DramaQueenDiva thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and would like to know if you keep having problems pairing your watch? If so, I recommend taking a look at the help article Why can't I set up my Fitbit device? and follow the instructions provide there.
Let me know the outcome.
10-10-2018 19:21
10-10-2018 19:21
I have the same issue as well, had tried Alenjandra's solution but to no avail.
Considering this is my first fitbit product, this is frustrating and also very disappointing.
Any help would be greatly appreciated. Else I would probably have to return it 😕
10-12-2018
06:25
08:00
10-12-2018
06:25
08:00
It's great to see new faces @esperanzalim, welcome!
Thanks for troubleshooting this by yourself. I would like to know if you keep having problems pairing your watch? If so, can you please tell me which steps have you tried so far?
Hope to hear from you soon.
05-22-2020 15:52
05-22-2020 15:52
Hello Support...
I have tried to use the steps listed on “How to setup my Fitbit”. I’ve reinstalled software on Android device, I’ve force stopped, I’ve turned off Bluetooth, and such.
The Versa gets stuck on pairing numbers screen, shows numbers have it to type in then software on Android shortly prompts try again, press, new set of numbers and looping at this point, help!!
please contact me either here on by email rdavisof@gmail.com, please.
10-12-2020 09:58
10-12-2020 09:58
what is the number?
10-12-2020 10:12
10-12-2020 10:12
What is the veresa display number?
10-12-2020 16:43
10-12-2020 16:43
