05-16-2018
18:43
04:11
AlejandraFitbit
05-16-2018
18:43
04:11
AlejandraFitbit
After I charged my Versa for the first time, I lost the time on the clock face. I turned it off and on and it didn't work. I did a reset and I am now having to start all over re syncing it. I don't know why the time was lost.
04:16
08:36
05-20-2018
04:16
08:36
A warm welcome to the Community @dogkat.
Thanks for troubleshooting this by yourself. If your Versa is showing the time wrong, I recommend making sure that the timezone setting is correct by doing the following from your Fitbit app:
I hope this helps, let me know the outcome. ![]()
09-12-2019 18:15
09-12-2019 18:15
I am still having trouble with my Versa...it is 14 mins behind. When I looked at the Time Zone advanced setting, it didn't have the "Set Automatically" option as mentioned. Need help still with resetting my Versa clock. Thanks!
10-24-2019 20:55
10-24-2019 20:55
I'm having the same problem! Called customer support twice today and they walked through some troubleshooting steps and it seems to correct but within the hour of the calls, it would be behind. Right now it is about 30 mins behind.
11-13-2019 07:50
11-13-2019 07:50
Do anyone have the answer?
I have the same problem. My versa is 55 minutes slow
01-17-2020 02:40
01-17-2020 02:40
Versa Lite is not changing my time zone to EST US & Canada even though I went into advanced settings and used another time zone and then reset it to United States
01-17-2020 10:10
01-17-2020 10:10
I finally fixed the issue by switching to Garmin! All the fitbit reps said it was an issue with my phone, clearly it was not! Very satisfied with my Garmin! Will never deal with fitbit again after being denied a replacement or refund when it was still under warranty. Very sad!
01-26-2020 12:11 - edited 01-26-2020 12:12
I was able to resolve the issue.
05-21-2020 05:51
05-21-2020 05:51
The time zone is correct. The battery ran down and when I got it recharged it will not reset to the correct time.
06-04-2020 13:08
06-04-2020 13:08
Mine did this too. I unpaired it from my phone and then paired it again. That fixed the problem
06-08-2020 15:57
06-08-2020 15:57
Did it continue to work? Mine will show the correct time but then fall behind again.
Best Answer06-11-2020 12:55
06-11-2020 12:55
Best Answer10-01-2020 05:11
10-01-2020 05:11
It does not work. This is such a piece of **ahem** product.
Best Answer10-08-2020 04:50
10-08-2020 04:50
This fix did not work for my versa 2. I went from having to charge it every 4-5 days to having to charge it every other day. It has been losing time for about a month and is 7 minutes behind.
10-09-2020 10:27
10-09-2020 10:27
After troubleshooting in the phone fir over an hour.. I did factory rest.. now shows correct time
Best Answer11-09-2020 09:15
11-09-2020 09:15
That's what they are telling me. So frustrating when I could go with a Samsung watch for the same **ahem** price. It all started when they put that spo2 update out. It's totally a malfunction on their part!
Best Answer06-03-2021 10:41
06-03-2021 10:41
Same with mine, doesn't hold charge and is always 6 mins slow, tried unpairing it and restarting it and it doesn't correct itself
08-22-2021 08:53
08-22-2021 08:53
Have the same issue as everyone else with time running late.
Told that you need to have the app on in the background 24/7 and that there's nothing else you can do to fix it.
Funny enough the time and watch worked fine for the first year I had it. Yet somehow this is my fault now for not having the app on in the background. Was also told that not syncing it for 24 hours was too long despite me saying that syncing it only fixed the issue about 80% of the time.
I would highly suggest if you can return the watch to do so. Support won't help and if you read a couple of the other forum posts on this same topic, you'll see that there really isn't a fix for this.
I even asked if Versa 3 would have this issue as I'd like to move off the faulty 2, but got no answer. Looks like Garmin or Apple Watch next.
Good luck to you all
05-28-2022 16:23
05-28-2022 16:23
The time on my Fitbit Versa is 3 minutes behind. I have reset it yesterday and today it’s not showing the proper time. It’s on Melbourne Time (AET) but it’s still 3 minutes behind.
Best Answer09-04-2022 07:38
09-04-2022 07:38
Jqualls' directions in his 1/28/2020 post worked for me. Do each step in order. Just fiddling with the time zone setting isn't enough
