11-23-2022 05:24 - last edited on 11-30-2022 06:56 by AndreaFitbit
Hi, my Versa started flashing white. After that when I turned it on, the touch wasn't working. By now I can't even turn it on anymore. Wondering if it's a short circuit...
I was swimming in the pool before this started. Did it many times before without any problem.
Moderator Edit: updated subject for clarity.
11-30-2022 06:55
11-30-2022 06:55
Welcome to the Fitbit Community, @Reese98. I'm sorry to hear that your Versa 2 screen is not turning on.
Thank you for letting us know that you already contacted our Support Team.
Thank you for your advise @NellyG.
We're happy that you'll be back on track soon.
11-24-2022 03:41
11-24-2022 03:41
Hi @Reese98 That doesn't sound good at all. Have you tried Restarting it? If not give that a try and also try a factory reset if you can. If it is still under warranty then contact Fitbit Support
Helen | Western Australia
11-28-2022 09:56
11-28-2022 09:56
I tried charging it and restarting but it didn't work. I did contact online support.
11-30-2022 06:55
11-30-2022 06:55
