10-25-2019
17:48
13:27
10-25-2019
17:48
13:27
I noticed that the time on my versa is slow by 1:15. I have checked and compared it to four clocks (two manual and two whose time comes from the network). How do I correct the time?
10-26-2019 01:27
10-26-2019 01:27
Hi @Joanna-p It should correct when you sync your tracker to your app. If it isnt, try restarting the Versa several times and then sync again. Hopefully that will fix it.
Helen | Western Australia
Best Answer11-22-2019 22:40
11-22-2019 22:40
Is your watch now working. This has just happened to me and I have been told by Fitbit that it is a problem they cant immediately fix. It is on Los Angeles time and as I am in UK we are 8 hours ahead so I have had to stop wearing Versa as it wakes me in the middle of the night. It doesn’t seem to be syncing either
Best Answer12-22-2019 14:36
12-22-2019 14:36
I'm having this issue a lot!
Was there any update? Restarting my Versa up to 6 times a day is not a solution.
Best Answer12-22-2019 23:49
12-22-2019 23:49
