12-30-2018
12:29
17:47
EdsonFitbit
12-30-2018
12:29
17:47
EdsonFitbit
My Versa synced in the middle of the night and now will not sync. Says syncing error, please try again later. Any suggestions? Has worked just fine since Christmas until today.
Moderator edit: added label
12-30-2018 12:49
12-30-2018 12:52
12-30-2018 12:52
if nothing has changed with your equipment, you may want to restart your versa. Once a week or so my versa will stop synching without rhyme or reason and restarting it usually fixes me up....
Elena | Pennsylvania
12-30-2018 12:57
12-30-2018 12:57
Try this video's instruction it may help you. Also make sure you havent turned off the notification by accidently long pressing the left side button and touching the notification option.
Best Answer12-30-2018 23:43
12-30-2018 23:43
