12-03-2020
13:47
03:33
12-03-2020
13:47
03:33
All of a sudden my versa 2 quit vibrating when I received a text message. Phone calls still work. I have done ALL the trouble shooting found on this forum as well as others.....including factory reset. What to do?
12-04-2020 14:16
12-04-2020 14:16
Hi there @melissa1966, welcome on board. Thanks for already troubleshooting your Versa 2's vibration motor prior to posting here.
Please confirm if you've tried all the steps provided in this help article: Why didn't my Fitbit device alert me?
Looking forward to your response.
Best Answer12-04-2020 14:28
12-04-2020 14:28
Best Answer12-04-2020 17:51
12-04-2020 17:51
You are not alone in this issue. I get my call notifications, but not my text ones. I know the haptics are working, the notifications are enabled and the fitbit and my phone are NOT in Do Not Disturb mode. Tired resetting the Versa 2, deleted it from my account and set it up again and checked all of the settings. Hopefully, they come up with an answer soon.
Best Answer12-04-2020 18:14
12-04-2020 18:14
Best Answer12-05-2020 03:36 - edited 12-05-2020 03:36
Hi there @melissa1966 and @goaliegirl, I appreciate you had followed the tips and recommendations provided above.
Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best Answer12-05-2020 05:37
12-05-2020 05:37
