07-30-2020
09:59
07:21
07-30-2020
09:59
07:21
I’ve only had my versa for a month. I seen it’s WR to 50 meters, so just to test it, i showered with it today. BIG MISTAKE! Now it won’t even turn on. This was my anniversary gift from my husband this year.
please help!!!!
07-31-2020 07:25
07-31-2020 07:25
Hi there @Stefnbrooklyn74, welcome to the Community Forums. I'm sorry to hear that your Versa stopped working after you took a shower with it. I'll be glad to help you with this situation.
Please note that all Fitbit trackers and smartwatches are water-resistant, which means they're rainproof and splash-proof and can stand up to even the sweatiest workout. Fitbit Versa Series are swimproof in a lake, pool, or ocean (up to 50 meters).
To better assist you with this inconvenience, can you please let me know if the heart rate sensors are flashing or is your watch completely unresponsive? If you haven't already done so, I recommend following the troubleshooting steps from this help article including steps to clean your device and restart it: Why isn't my Fitbit device's battery charging?
I'm looking forward to your response, keep me posted.
07-31-2020 08:33
07-31-2020 08:33
Yesterday the green light would flash when i hit the side button. But the screen was totally blank. Now today, when i hit the side button no green flashing light & the screen shows 0%. I put it on the charger for well over 3 hours now & it still says 0%.
i can’t do anything with it.
Best Answer07-31-2020 08:46
07-31-2020 08:46
Hi there @Stefnbrooklyn74, thanks for getting back and for the update. As I suggested above, if your watch doesn't vibrate when you connect it to the charger, I recommend doing the following:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Let me know if you need further assistance, I'll be around.
Best Answer07-31-2020 09:31
07-31-2020 09:31
I cleaned like u said, i changed outlets. I pressed all 3 buttons. The only thing that happens is the screen shows 0%. This is insane! The watch clearly says WATER RESISTANT to 50 meters! U said, splash proof! That’s a HUGE DIFFERENCE! Nonetheless, i will tell everyone i know NOT to purchase this product. How can something be advertised for fitness if it can’t even go in water? I didn’t even submerge it! All i did was shower with it & it’s DEAD!
Best Answer07-31-2020 11:51 - edited 10-03-2023 17:12
Hi there @Stefnbrooklyn74, thanks for the update. I understand where you're coming from. At this moment, I’ve reached the limits of what I can do for you here on the public community forums, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
