08-16-2020
00:43
13:33
08-16-2020
00:43
13:33
Fitbit versa not staring , when I tried to reset by holding all the buttons for atleast 20 seconds does nothing. But after few mins fitbit logo comes up and it's stuck up there.
Hi there @Akshaykumar, welcome to the Community Forums. Thanks for the details provided in your post about your Versa's screen behavior and for taking the time to restart it prior to contacting us.
Since the restart hasn't worked and your watch is still stuck on Fitbit logo, I recommend doing a factory reset:
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Give this a go and let me know how it goes, I'll be around.
Hi there @Akshaykumar, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know. 🙂
