07-07-2022
06:44
09:11
07-07-2022
06:44
09:11
Watch screen stuck on fitbit logo since I tried to set it up with my Samsung galaxy a33 phone. Was working before that. Can't even sync watch to phone
07-07-2022 09:13 - edited 11-16-2023 10:49
Hi there, @Emz90. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out.
It seems like you have unpaired the Versa from the Fitbit app, but not from the phone's Bluetooth settings, so your watch is asking you to pair it again. Note the error message you're receiving on your watch's screen usually appears when you've performed a factory reset without first unpairing the watch from the phone's Bluetooth settings.
That being said, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope this helps.
Best Answer07-07-2022 16:39
07-07-2022 16:39
Unfortunately I can't do any of that as my fitbit is stuck on the logo screen and had already removed it from Bluetooth devices
07-08-2022 06:37 - edited 11-16-2023 10:44
@Emz90 I appreciate you had followed the tips and recommendations provided above.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
See you around.
07-11-2022 02:56
07-11-2022 02:56
Hi thanks for your help. I dont know how this worked but I waited for my fitbit battery to go flat, then put it on charge to see what it would do and it has seemed to have fixed itself. Even got phone conected. Just thinking should I contact support team to let them know as hopefully that is it fixed
