04-05-2018 16:19 - edited 04-22-2018 16:12
Downloaded software for Versa. While it was installing, the process froze. I have done the following to remedy the situation: turned Versa on and off, erased and re-loaded fitbit software on iPhone, Turn phone on and off. Removed versa from Bluetooth discoverable list. No longer discoverable. Disconnected all other Bluetooth devices from Phone. Nothing works because every time I turn watch back on again it returns the frozen installing state (loading bar still on screen) Can’t get help from Fitbit. Any suggestions? Is it possible to reset the Versa to factory settings using the buttons on the sides?
UPADTE April 21/18
So my latest Versa works fine...so far. Did a FIIIT workout today and the watch handled it admirably. Fitbit pay works well, but so far in Canada, only the Royal Bank is on-board -- you can only store a credit card, not a debit card. The biggest pain has been replacing the watch strap, but it's a minor quibble. Will update as necessary.
03-06-2019 05:44
03-06-2019 05:44
Best Answer03-16-2019 15:18
03-16-2019 15:18
I went through every possible scenario suggested by the Fitbit support team, as well as things that I read here, and other things that I found on the Internet. My Fitbit Versa was stuck in “fetching” screen. It would flash the screen on and off every second or so, and continued saying the word fetching. I deleted and downloaded the Fitbit app, I turned on and off the Bluetooth, and the wireless, I did a factory reset… Nothing was working it would flash the screen on and off every second or so, and continued saying the word fetching. I deleted and downloaded the Fitbit app, I turned on and off the Bluetooth, and the wireless, I did a factory reset… Nothing was working. Then I decided to try to download another clockface and viola’ — it worked. Seems the clockface I was using was the problem! My Fitbit is now working, receiving texts, alerts, counting my steps etc.
Best Answer03-17-2019 11:38
03-17-2019 11:38
Bought my versa in oct last year, and except for the firmware update a few months ago that resulted in some syncing and notification issues (i have to restart when notifications stop and they'll restart), things were pretty much fine. Cut to this morning when i woke up and tried to see the time and realized the watch had reset... logo was onscreen with the message to setup using the fitbit app... 5 hours later and i have tried everything, now trying to setup as a new device but the same thing keeps happening, the software downloads but does not install, and it just keeps re-downloading then going back to logo + install fitbit app to setup message. I am trying now over bluetooth only, but am understandably not hopeful!
Best Answer04-07-2019 07:18
04-07-2019 07:18
At first I was believing that is was a Bluetooth issue. Well this morning I tried to sync again and it won't. Went to my router, took the versa off and placed it on the router. Went to the Fitbit app, clicked on wifi settings, it showed my wifi, clicked that, then my versa showed the wifi symbol on the face, went to my dashboard, and it synced. So do I assume my WiFi is weak? No way my wifi works all the way out of my house like 100 feet. Maybe the wifi detect in my watch is weak. Just frustrated with the versa. Never any connection problems with my charge HR or my blaze
Best Answer04-07-2019 18:02
04-07-2019 18:02
Best Answer04-07-2019 20:37
04-07-2019 20:37
I returned my first one, and just boxed up the second one to return to amazon. They are great accepting returns. My first one the Fitbit customer service was great. Shout out to Benjamin. But having to send it to fitbit and paying return shipping, then waiting 5 days for them to replace, then not sure if you are getting new or refurbished. I did not want a refurbished one for $199. So I'm glad I bought from Amazon.
Best Answer05-15-2019 10:45
05-15-2019 10:45
Dear @Ishrogh
How did you solve the problem with the vertical progress installing bar that re-appears and the fitbit is stuck again? I have the same problem.
Best Answer06-21-2019 18:20
06-21-2019 18:20
How do I install it with WiFi?
Best Answer09-04-2019 11:18
09-04-2019 11:18
WOW.... this is crazy.. they tried to make feel like it was my phone.. I said it is a NEW ANDROID.... she even made me tell the version of my android....
Best Answer09-08-2019 07:22
09-08-2019 07:22
I am throwing mine in the garbage. Anyone want it? It's been over a year and it won't update. It just hangs and hangs over night. Them gives an error message. Not worth the stress. I am.guessing it doesn't work with Samsung S9. Too bad. It has some nice features when it worked when I first got it.
Best Answer09-08-2019 08:00
09-08-2019 08:00
It is a shame we spend over $200 for something and if they decide to replace it they will with the same one giving you the problem. I am so disappointed as I have been a fitbit user since 2013!
Best Answer05-01-2020 12:27
05-01-2020 12:27
When it got to that stage and it wouldn’t go anymore what did you do please? My brand new Fitbit Versa lite is stuck on installing not even half way across the screen. What do I do to fix this please or is it faulty?
Best Answer05-01-2020 12:31
05-01-2020 12:31
thats exactly what mine is doing right now and it’s brand new, what did you do to fix it please? Really need your help I’m stuck iv tried everything.
Best Answer05-01-2020 13:09
05-01-2020 13:09
Best Answer05-01-2020 13:24
05-01-2020 13:24
Best Answer05-01-2020 14:49
05-01-2020 14:49
Best Answer05-01-2020 15:49
05-01-2020 15:49
Best Answer05-01-2020 15:51
05-01-2020 15:51
Get ahold of Fitbit support. It has a 2 year warranty. They should send you a new one
Best Answer08-20-2020 19:18
08-20-2020 19:18
hello can you fix your problem ? i have de same
Best Answer08-20-2020 20:13
08-20-2020 20:13
