01-14-2019 07:07
01-14-2019 07:07
My versa will not go off the logo it will go on and go off . wont shut down wont paor so lost
Best Answer01-14-2019 07:08
01-14-2019 07:08
I am having the same issue and my steps aren’t being captured.
Best Answer01-14-2019 07:21
01-14-2019 07:21
Hi, try restarting your phone, sometimes this has to be done several times. Good luck!
Best Answer01-14-2019 07:42
01-14-2019 07:42
Best Answer01-14-2019 07:44 - edited 01-14-2019 07:44
Hi, then I would advice you to contact Customer Support about your problem.
