07-02-2018 21:33
07-02-2018 21:33
I have a OnePlus-3 and was wondering if all the features of Fitbit versa are supported on it? If not, which ones don't work on the OnePlus-3?
07-03-2018 11:39
07-03-2018 11:39
I have a Versa and OnePlus 3T. Syncing, notifications and connected GPS all work ok, so it seems to be compatible.
07-02-2018 23:19
07-02-2018 23:19
It is not a Supported Phone so there is no list of what works and what doesnt. With unsupported phones, they may work fully or they may not work at all, they might be variable and unreliable in syncing or they might sync perfectly for a time and then stop (usually after an update to phone or fitbit). There is no where that will tell you what features work and which dont, and if their was a list like that it would still be variable. However when a phone is not Supported the most common feature to suffer is notifications, with syncing problems being common too.
Helen | Western Australia
07-03-2018 10:20
07-03-2018 10:20
07-03-2018 11:39
07-03-2018 11:39
02-20-2019 13:29
02-20-2019 13:29
Hi there,
I've recently bought the versa and having trouble syncing with my OnePlus 3T. Do you have any tips? So frustrating!
Catherine.
05-18-2019 18:31
05-18-2019 18:31
Just purchased a Versa and it connects once and then
05-18-2019 18:34
05-18-2019 18:34
Just picked up a Fitbit Versa. Connects once with my OnePlus 3 phone.then no more connectivity. No issues with my previous FitBit Charge..
Any ideas short of returning the device?
