Versa syncing issue
Hello.
Literally purchased this today and I already want to send it back.
Nothing I do will allow the blue tooth/ syncing to work.
Multiple times I've rebooted phone, rebooted versa, paired, tried to sync, updated software, and done everything but it isn't working.
Can you help or shall I just send it back and go to another product.
2 REPLIES 2
It sounds like you've tried all the normal troubleshooting steps.
Have you checked that your phone is supported by fitbit at www.fitbit.com/devices ?
Thanks for your reply!
Yea I've had other fitbit with out issues (removed them from my Bluetooth list) and I couldn't see any issues. It managed to come CT for two mins to upgrade the hardware but then nothing.
Cheers
