07-27-2019 16:58
07-27-2019 16:58
why is Versa suddenly stopped syncing and the clock showing the wrong time
07-27-2019 18:26
07-27-2019 18:26
Hi @Magsinspain The time will be wrong becausenit is not syncing. It needs ro sync to correct it. What phone are you using? Is it on the Supported Devices List?
Try all the steps in THIS Help Article on syncing
Helen | Western Australia
07-27-2019 20:34
07-27-2019 20:34
It’s an IPhone 6S been working for 5 months
Best Answer07-27-2019 20:38
07-27-2019 20:38
Have had to revert to my Alta Hr which is syncing fine thanks for replying
Best Answer07-28-2019 00:59
07-28-2019 00:59
Yes, it should sync with that phone. Try all the suggestions in the Article I linked above and see if you can get it working again.
