02-06-2020 12:58
02-06-2020 12:58
All of a sudden my brightness and tracker wake up mode changed and when I go into settings they are dim. I tap on them to change them but nothing happen. I have restarted the tracker and synced with the phone app amd nothing has changed.
02-06-2020 16:09
02-06-2020 16:09
Hi @JenLyons Try a Factory Reset (settings app on the watch and then scroll down to About) You will then have to set your watch up again as a new device.
Helen | Western Australia
02-06-2020 16:11
02-06-2020 16:11
Thank you. I actually just solved the problem by trying to scroll through other posts to see if there was anything similar. I found one that said see if it is in sleep mode. It was and that fixed everything.
02-07-2020 05:21
02-07-2020 05:21
Oh yes, of course! Glad you have it sorted now.
