Versa vibrating randomly
My Versa is randomly vibrating quite often. It just started doing this. It is very aggravating. It keeps me constantly checking to see if there is a notification but there is nothing there, just my clock face. Any help on this would be greatly appreciated.
6 REPLIES 6
I have this issues sometimes as well.  I was wondering the same thing.
There are times that my movement results in one of the side buttons being pushed - but usually when that happens my screen lights up and often opens something.
But sometimes I feel it vibrate and the watch face is black and wakes up to the clock screen.
So far, I have had only the issue that you mentioned at the end. I look down at my Versa and it wakes up to the clock screen.
Sent from my iPhone
My Versa has started to do this as well.  I can no longer wear at night to track my sleeping because it will start vibrating and will vibrate every couple of  minutes until the battery drains.  Since this doesn't seem like an Isolated issue does Fitbit have a solution?
Mine hasn’t done it for a while. Can’t really say why. I did change the face. That might have fixed it. Don’t know if Fitbit has an answer or not.
Thanks for responding.
I left mine alone for a week or so with the battery drained before
recharging and it stop vibrating, but now I am having other issues.
Thank again.
Your welcome, good luck
Sent from my iPhone
