02-03-2019
20:55
11:38
AlejandraFitbit
02-03-2019
20:55
11:38
AlejandraFitbit
Hi All, please assist.
My Versa will not turn on. I’ve had it for just over 6 months now, and over the pas week I’ve gotten emails saying battery low, I put it to charge and it’s fine and then by the night again it’s low. Yesterday I put it to charge for over 12 hours and it now not coming on. I’ve read other post here and even tried all 3 buttons for 3 minutes. Any suggestions please.!
Best Answer02-04-2019 00:55 - edited 02-12-2019 21:24
@Joachimg Please try 3-button factory reset:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
If you're successful with factory reset, please remember to remove Versa from your Paired Devices list in your phone Bluetooth settings as you will have to set it up again (add as a replacement device).
If the factory reset does not work, please reach out to Customer Support to guide you through the next steps.
02-03-2019 20:58
02-03-2019 20:58
@Joachimg are the sensor lights blinking? What happens when you put Versa in the charging dock? Have you tried rubbing the contacts with alcohol and plugging the tracker to USB port of your computer to charge?
02-03-2019 22:31
02-03-2019 22:31
02-04-2019
11:43
03:30
02-04-2019
11:43
03:30
Hey @Joachimg, it's great to see you around and @Marrrmaduke thanks for the input.
I appreciate all the efforts in trying to fix this display issue by yourself. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution.
Let me know if you need anything else. ![]()
Best Answer02-14-2019 21:10
02-14-2019 21:10
Best Answer02-15-2019 13:14
02-15-2019 13:14
@Joachimg Try performing a factory reset. This will wipe your Versa, so please sync first. You will also need to delete your tracker from your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a replacement device in the Fitbit mobile app. Let me know if that helps.
02-15-2019 18:51
02-15-2019 18:51
Best Answer02-15-2019 20:24
02-15-2019 20:24
@Joachimg When did you factory reset your Versa and what's the battery drain after the reset?
02-15-2019 23:48
02-15-2019 23:48
Best Answer02-16-2019 00:34
02-16-2019 00:34
@Joachimg I meant for you to perform a factory reset as described in my previous post. Some users reported this issue on the forum and were able to resolve it with a factory reset (or several). If factory reset does not help, you will need to reach out to customer support, I'm afraid. Btw, why do you think the device was not new? Does it have marks?
02-16-2019 01:58
02-16-2019 01:58
Best Answer02-17-2019 19:28
02-17-2019 19:28
@Joachimg Mine didnt have the tape either and I got it from when it was released. I know fitbit doesnt ship the full kits. They ship mainly new devices (sometimes refurbished) but to save on the shipping costs they do not include original packaging and accessories. Can you attach the picture of the marks?
Best Answer02-22-2019 05:39
02-22-2019 05:39
My versa, after days of low battery notifications, now will not charge or turn on. It's obvious this product was not ready for market, I will be returning it to Costco.
02-22-2019 05:42
02-22-2019 05:42
Best Answer02-22-2019 05:53
02-22-2019 05:53
Best Answer02-22-2019 06:01
02-22-2019 06:01
Best Answer02-22-2019 10:25
02-22-2019 10:25
Can I please get advise on how to get a total refund! Disgusted by the support and service I’ve been getting.
will reccomend that no one buys this device .
Can someone anyone please advise.
Best Answer02-22-2019 10:33
02-22-2019 10:33
Best Answer02-22-2019 11:21
02-22-2019 11:21
