How old is it?
Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
Wendy | CA | Moto G6 Android
Hi it’s just over three months old and I’ve tried everything
Contact support use help at top of forum
@Carolalbin do you charge it from the electrical outlet? Switch to USB port and see if charging using your computer works.
Best AnswerUnfortunately, same thing happened to me!
It was just on 60% and then it all went black. I tried re-charging. The interface goes back up but won't get past to 1%. Once you take it off the charger, it's just dead! I tried to troubleshoot + factory reset but nothing works.
- basically do a factory reset by holding all the 3 buttons for 12 seconds and once a logo appears, let go of the lower right button (if this works for you, let me know, because it didn't for me)
- charging it all kinds of outlet (laptop, USB port, wall)
- I even cleaned the back part of my Versa with toothbrush and dabbed+dried the pins of the charger with alcohol
I contacted customer service. The chat agent was great. I am now doing an e-mail exchange. They decided that it might just be the charger with all the videos I sent. They'll be sending a charger replacement instead. I'm from the Philippines so imagine how long will that take. Imagine also the frustration when I try the new charger and it still doesn't work and it ends up being the hardware fault at all.
Oh! Quite frustrating!
Oh and just bought mine last June.
@vintagechutzpah wrote:Unfortunately, same thing happened to me!
Just an update. The charger arrived within one week. They shipped it from China so it was fast to get here in the Philippines. Unfortunately, it ain't a charger problem. I plugged it in the new charger they gave me but it reacts the same way. I've just e-mailed them now asking what to do next.
I called in the retailer wherein I purchased the Fitbit from. It's still under warranty. So, that's an option to just give it back there. The process time though would take 2-3 weeks as it has to go to their HQ and personally inspect it before any decision of giving a new replacement or what have you.
WHAT A HASSLE. Anyway, I'll wait for the Fitbit team to reply first.
