I have had my Versa for a year and 3 months and up until 2 days ago it was awesome. Suddenly out of nowhere I go to look at the time and it is dead. So dead that it takes a minute in the charger before it will even show 0% charge. I have not changed any settings. I had not even changed the face before this started happening.
Laat at night I charged it to 100%. In less than 12 hours, it is down to 16% and falling. It went from 36% to 18% in an hour and 8 minutes.
This is exactly why I got rid of my Apple Watch-because it had to be charged every 8-12 hours.
I have tried restarting the watch. I have turned off virtually everything other than syncing. This is a pretty crummy thing if it just lasts until it’s out of warranty, then dies. I thought FitBit was better than that. Please tell me something can be done.
I'm having similar issues, but have only had mine since February. I'm lucky if the battery lasts 6 hours now. Even just sitting at my desk doing nothing but work today, I'm down to 55% battery when it was fully charged at 8 am. Pisses me off to no end. I'm going to try to contact customer service and would suggest you do the same.
Best AnswerI have the same issue. The battery dies very quickly. It won’t even charge to 100% when it’s been on the charger a whole day! I’ve tried all the troubleshooting options I could find online an it’s not any better. Someone help us please
Best AnswerI called customer service and they had me do a battery drain test, which they can monitor from their end. It was determined that mine was indeed not functioning correctly and a new unit is being sent to me (should arrive today) at no cost. Mine is still under warranty, however, so if you have one more than a year old, you may be out of luck.
Best AnswerI’ve been working with support via email and they’ve had me try a couple of charge/discharge steps. Not sure what other options I might have.
Best AnswerSame problem here. They have no solution. Battery cannot be replaced. They will tell
you to buy a new one. Sad and wasteful. Just went through this and I’m not sure what I’m going to do.
