05-18-2020
15:28
13:34
05-18-2020
15:28
13:34
I have a fitbit versa and I am trying to change the clock face and access apps. When I go to the Fitbit app and try to click on the clock faces and apps they show the loading symbol but they are not showing up. Does anyone know how to fix this?
05-25-2020 13:33 - edited 10-14-2023 09:16
Hello everyone. I apologize for the delay in my response. I'm sorry to hear that you're having issues installing clock faces on your Versa smartwatches. I appreciate all the steps you've done so far to get this fixed.
I must say that I really appreciate all of you are helping each other. Said so, if you're still having trouble installing clock faces, please try the following:
If these troubleshoots, don't work:
Hello @Madhornist in regards to your last post, I wondered if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 and higher, Android OS 7.0 and higher.
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
05-18-2020 15:35
05-18-2020 15:35
Hi @MadelineGoulddd , restart your Versa three times in a row by pressing and holding the left and right lower buttons together untill you see each time the Fitbit logo and release the buttons. After that, sync again with your Fitbit app and see if you now can get to the clocks and apps section. Erik
05-18-2020 17:32
05-18-2020 17:32
05-19-2020 13:38
05-19-2020 13:38
I tried this as well, and it didn't work for me either. To be clear, this is occurring at the point of selecting the clock face, not when you're loading it onto the watch. So unless there's some weirdness with the app that requires communicating with the watch when you're just looking at clock face options, resetting the watch shouldn't really help. And it doesn't. The problem is with the app. In my case, it's the Android version, if that helps.
05-19-2020 14:29
05-19-2020 14:29
Hi @MadelineGoulddd , try this: on your Versa swipe to the apps page and choose clocks. Choose the one you want and it should change it. Works for me. Erik
05-19-2020 15:00
05-19-2020 15:00
05-19-2020 15:04
05-19-2020 15:04
Hi @Madhornist , do you have a Fitbit Lite? Erik
05-19-2020 15:05
05-19-2020 15:05
05-19-2020 15:14
05-19-2020 15:14
Nope, just a regular Versa. Not a Versa Lite, nor a Versa 2.
05-19-2020 15:24
05-19-2020 15:24
Hi @Madhornist , if you do not have have the clocks app on your watch, nor within your Fitbit app, your Versa is not compatible with this app. Try this: go to the Apps page and press all apps and search for Clocks. If that not shows up on the list, unfortunately it does not work with your Versa, probably only with the Versa 2. Erik
05-19-2020 15:36
05-19-2020 15:36
05-19-2020 15:54
05-19-2020 15:54
Hi @Madhornist , if you do not have the Clocks app available for your Versa, this problem cannot be resolved. Erik
05-19-2020 20:20
05-19-2020 20:20
05-20-2020 21:17
05-20-2020 21:17
Okay, I've done a bit more research. I don't know if this has anything to do with it or not, but I figured it can't hurt to ask.
My phone is running the mobile app version 3.4.2. Since it's an Android running OS 6, this appears to be the latest version available for this phone. So I'm wondering if there was some recent change on Fitbit's side that has disable clock face loading for the Fitbit app 3.4.2 (either unintentionally or out of necessity for updating the more advanced versions).
