10-16-2019
14:45
05:29
JuanJoFitbit
10-16-2019
14:45
05:29
JuanJoFitbit
Why won’t text messages come through on my Versa after the latest Apple update? I’ve looked every place that I know of, and it still won’t work. I get phone calls, just not texts. Is this an issue with the update or is something not switched on? I never had this problem before.
10-16-2019 14:54
10-16-2019 14:54
You might want to read the pink banner above, then subscribe to the thread on this subject.
Apple changed something and did not provide a notification of the changes.
10-17-2019 05:29
10-17-2019 05:29
@CJCOOK welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it's not receiving text messages even though you've tried to fix this issue before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. After this, monitor your Versa and see if the issue gets fixed.
Thank you for your help @Rich_Laue.
Keep me posted on the outcome.
Best Answer10-17-2019 13:06
10-17-2019 13:06
literally just tried this tonight and step 3 on all the advice that’s been posted is critical, as soon as I made sure my iphone had the latest update (there was one sitting there waiting to update and I hadn’t realised) I went into settings on iPhone tapped notifications and right at the top there’s a toggle that says show previews, never noticed it before, toggled it to always and all my notifications started coming through....hope this helps
3. CHECK YOUR NOTIFICATION SETTINGS
Best Answer10-17-2019 13:18
10-17-2019 13:18
I checked that already, didn’t make a difference.
