12-12-2019
11:35
11:51
12-12-2019
11:35
11:51
Hi
I am using fitbit versa. There is no response and power on from last 2 weeks please advise to rectify the issue
Thanks
K.Bala
12-13-2019 12:02 - edited 09-25-2024 07:35
Hi there @Ramkbala, welcome to the Community Forums.
Please try charging your Versa for at least 1 and then perform a restart on it by following these steps. If the restart doesn't work and the display is still not turning on even after the recommended steps. Please take a look at the help article: Why isn't my Fitbit device's battery charging?
We recommend to charge your trackers via the USB port over a wall adapter. However, it is also possible to charge your Fitbit tracker with a UL certified wall adapter. Don't leave your device plugged in on the charger during storage.
Tips to best charge Fitbit trackers are:
For charging purposes, your charging cable can be plugged into any USB power source, including but not limited to:
Let me know if you need further assistance, I'll be around.
Best Answer12-13-2019 12:02 - edited 09-25-2024 07:35
