10-13-2020 16:41 - last edited on 01-22-2021 16:04 by LiliyaFitbit
Hi my Versa won't sync and it is forcing me to do am update but the update keeps failing.
I've been having a similar issue... I setup my Versa and it will work fine for 10-15 min then it just disconnects and won't reconnect till I power cycle both phone and watch and run the setup again...
Best AnswerI keep having this issue and I'm tired of it. This is a $200-$300 watch and it keeps working this poorly? I use to be a big supporter of fitbit but this watch,, versa 2 has caused me to change my opinion. I think that this will be my last fitbit product unless I see some official communication about this issue, what caused and exactly what they did to fix it.
If the update keeps failing, you may need to connect your versa to a different Wifi and make sure your are close as possible to the router.... the Versa has a very limited wifi range and that could be why the update keeps failing.
Best AnswerYes, I can assure you that I have similar issues, and I've already had to have my Versa Lite replaced once. It just simply stops keeping accurate time or syncing for no particular reason. I try manually syncing, I try turning it off and on in the settings on the device -- nothing is helping. Probably need it replaced again!!
