09-19-2019 09:24
09-19-2019 09:24
Every morning I try to sync and "device not found" shows up after "looking for device".
AFTER I restart everything phone, fit bit (turn off fitbit, turn back on) Bluetooth off then back on, then sync to versa... STILL only works sometimes.
I don't wanna do this every darn morning!!
I've tried to reinstall the app as well.
Didn't help at all.
HELP ME!!
I've been a fit bit user for almost 5 yrs. I don't wanna give up fitbit, but definitely not worth all this hassle.
09-19-2019 11:52
09-19-2019 11:52
Growing problems exactly like yours are appearing on this forum. My Versa Lite stopped syncing yesterday morning and nothing I do seems to fix it.
Best Answer09-19-2019 12:14
09-19-2019 12:14
Hi @KittiEKat Have you tried uninstalling the fitbit completely and unpairing from bluetooth and then re-installing and re-pairing into bluetooth?
I find with the versa that my connection with my phone can sometimes be a bit wonky. So, I find that restarting my phone sometimes works as a quick fix.
Best Answer09-19-2019 14:53
09-19-2019 14:53
