12-17-2018
17:08
10:05
HeydyF
12-17-2018
17:08
10:05
HeydyF
My versa wouldn't connect to my phone so I tried turning on and off bluetooth, but that didn't work. Then I tried restarting my versa a couple of times and it still wouldn't connect. So i unpaired it in the fitbit app and restarted the whole process. Still nothing. So I factory reset it and now it wont even turn on. Any suggestions on how to fix it?
Moderator edit: Subject for clarity and format
Best Answer12-17-2018 17:17
12-17-2018 17:17
@CJ2018 Put it back on a charger for 2 hours and try rebooting it again by pressing and holding the left and bottom right buttons until Fitbit logo flashes. If this does not help, try performing 3-button factory reset as follows:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
12-18-2018 19:46
12-18-2018 19:46
I have tried this multiple times and my watch still won't turn on. Its only 4 days old...
Best Answer12-18-2018 20:15
12-18-2018 20:15
@CJ2018 Does it react at all when you plug it for charging? Try using USB on your computer. Also, try to rub the contacts with alcohol and plug for charging again. If factory reset does not help and your tracker does not react to charging, then I'm afraid you will need to reach out to Customer Support as this might be a hardware issue.
12-19-2018 07:18
12-19-2018 07:18
@CJ2018 Welcome to our Fitbit Community! I'm sorry to hear that your Versa is not turning its display on even after following the troubleshooting steps that provided my friend @Marrrmaduke. After cleaning the contacts as she mentioned, plug the Versa in the charger and leave it charging for at least 2 hours and see if it turns on.
If your tracker is still unresponsive, let me know and I'll be happy to follow up! ![]()
12-19-2018 15:12
12-19-2018 15:12
Thank you so much for all of the help. Unfortunately, wiping the contact points and charging it for two hours still did not turn my watch back on. Do you happen to have any other suggestions?
Best Answer12-20-2018 01:07
12-20-2018 01:07
@CJ2018 sorry for the delay. Life, life, life. At this point, I would recommend reaching out to Customer support as you may need a replacement. They will be happy to help. Good luck!
12-22-2018 03:39
12-22-2018 03:39
@CJ2018 Thank you for getting back and trying the troubleshooting steps shared above. Since the issue persists, I would like to know if you followed the advice that suggested @Marrrmaduke and contacted our Support team. If so, did they provide a solution?
Looking forward to your response! ![]()
