07-05-2020
10:48
05:32
07-05-2020
10:48
05:32
I have selected option factory reset in fitbit Versa after that screen didn't turn ON. Please guide me how to resolve this issue.
07-06-2020 05:34 - edited 06-19-2024 05:21
Hi there @Shetdarshan, welcome to the Community Forums. I appreciate the details shared in your post about what happened to your Versa and for taking the time to troubleshoot it prior to posting here, I'll be glad to help you.
While reading your posts, I wondered if your watch vibrates when you put it on the charger? It seems that the Factory Reset drained the battery and also looks like the battery may not be charging properly and therefore does not turn on. So, I recommend that you follow these steps:
I'm looking forward to your response, keep me posted.
Best Answer07-06-2020 06:57
07-06-2020 06:57
Best Answer07-06-2020 07:24 - edited 06-08-2024 11:19
Hi there @Shetdarshan, thanks for getting back. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
