10-05-2022
08:53
07:07
10-05-2022
08:53
07:07
I have a 3 year old Versa that now doesn't start at all. I've tried all the troubleshooting steps. The problem started when I recently switched phones from iPhone X to iPhone 13. At first it was difficult and took a long time to sync the Versa to the new phone and get the notifications to work. When I finally got it to work the Versa turned black and never turned back on again. As I said, I tried everything.
Hi there, @AmelieT. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Versa before reaching out. I understand where your concern is coming from.
As a first approach, I'd like to confirm that you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?
If the restart doesn't work and your Versa does not vibrate while trying to perform the restart, please make sure you've followed all the steps provided below:
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa from your phone's Bluetooth before performing this step):
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope this helps.
Hope this helps.
Best AnswerThank you Maria for taking the time to help me. I tried all the steps as per your instructions and unfortunately nothing helped.
@AmelieT I appreciate you had followed the tips and recommendations provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon! 🙂
Hi there, @JoeZ.. Thanks for stopping by. I understand how you must be feeling.
To better assist you, please make sure to follow all tips and recommendations I posted here.
Hope that does the trick for you.
