10-04-2018 16:14
10-04-2018 16:14
Best Answer10-04-2018 16:18
10-04-2018 16:18
Just tried the 3 button factory reset and that was also a fail. Back light came on and off but nothing on the screen.
Best Answer10-05-2018 13:08
10-05-2018 13:08
Hey @AsiaCC, it is great to see new faces around! If your Versa won't turn on, even after trying several tips to make it work, I suggest you to keep an eye on your inbox because I have escalated your case to our Support team for further assistance in regards of your warranty, so they will try to reach you anytime soon. 😉
Let me know how it goes!
Best Answer10-06-2018 01:36
10-06-2018 01:36
Im having the same issue , battery life is very short if it goes fully flat it takes days for it to turn back on. continually says its at 0% every now and then the fitbit symbol pops up but that's it. have only had mine since the end of june
Best Answer10-06-2018 12:43
10-06-2018 12:43
Hey @Night0wl, welcome aboard! Have you tried to restart your Versa to see if it comes back to life? If you haven't, please follow these instructions:
If your watch still not responding, let me know!
