10-15-2018
04:35
07:58
AlejandraFitbit
10-15-2018
04:35
07:58
AlejandraFitbit
I started having screen issues yesterday. Today my Fitbit won't come on at all. Not even on the charger. I have had it less than 6 months... anyone else run into this?
10-15-2018 04:57
10-15-2018 04:57
Have yountried restartingnit several times? Have you tried a Factory reset? Give those a try and if it still wont come on you will need to contact Support (link in my signature) Let us know how you go
FACTORY RESET USING BUTTONS
On the watch, hold all three buttons for about twelve seconds. This triggers the 2-button hardware reboot after about eight seconds.
- When the Fitbit logo appears, then disappears, release the bottom right button, then continue holding the left and top right buttons until you feel a strong vibration. This indicates the factory reset was initiated.
- This process may take several seconds, and eventually, the Fitbit logo appears and the device boots and displays go to Fitbit.com/setup.
- If you fail to release the bottom right button in time, or otherwise don't follow the procedure precisely, the Fitbit logo reappears quickly and boots without factory reset.
If the device turns on, please go back to the Fitbit app and setup your device back to your account with these steps. Make sure your watch is plugged into a wall plug or a computer, next to the router and that there are no other trackers or devices with Bluetooth on nearby when setting up. Please log into your account, go to account on the upper right corner, there look for "setup a device" and tap on it. Follow the instructions on the screen and let the watch charge for 2 hours.
Helen | Western Australia
10-15-2018 04:57
10-15-2018 04:57
10-17-2018
07:58
06:40
10-17-2018
07:58
06:40
Best Answer10-17-2018 21:57
10-17-2018 21:57
I am having the same problem! Nothing is coming on on my Fitbit. It has a black screen I have tried the factory reset and nothing happens!
10-17-2018 22:13
10-17-2018 22:13
Same issue for me. I plug mine into the charger into my computer and it says 0% charge but won’t charge. But right before it went black I was at 99% charge. I’m so annoyed as my Versa is less than a month old.
10-18-2018 05:03
10-18-2018 05:03
10-18-2018 20:56
10-18-2018 20:56
I took my Versa back to Best Buy. Several resets were attempted in the store. Nothing worked, so I must send it to FitBit. I am absolutely done with FitBit!! My Charge HR had to be replaced as did my Blaze. I gave the Versa a shot because I could see my progress over the years. BIG MISTAKE!! I would like a refund but FitBit will not refund my money. A device that I paid $200 for should work for more than 29 days!! I do not want a new Versa! I want my money back!!
04:32
06:40
10-19-2018
04:32
06:40
Thanks for the update @Jess1913, I am glad to hear that you contacted our support team and that a replacement were offered. If there is anything else we can do for you, do not hesitate to post it.
@1HOTNANA2018 welcome to the Community, @mdanielle1215 and @last14me it's great to see you around. I appreciate all the efforts in trying to fix this issue. Upon checking with our support team, I was told that all of you have already created cases with them. I know they will be glad to help you out and provide you a solution.
Keep in mind that if you are unsatisfied with your purchase from Fitbit.com for any reason, you have 45 days from the date of purchase to request a full refund. For more information check our warranty policy.
See you later. ![]()
Best Answer10-19-2018 05:21
10-19-2018 05:21
I called customer support yesterday. They are already shipping me a replacement.
10-21-2018
04:05
06:40
10-21-2018
04:05
06:40
Those are great news @mdanielle1215.
I am glad to hear that you will be receiving a new watch. At the moment of receiving it, you just need to do the following from your Fitbit app to set it up:
Let me know if you need anything else. ![]()
Best Answer10-22-2018 10:51
10-22-2018 10:51
Did customer service give you a hard time? Telling you to record yourself trying to troubleshoot or that you had to send it back before they could help you. They treated me like I was not being honest and Ive been an avid fitbit user for over 7 years. Ive never been treated so poorly by them before. Glad you had a better experience let us know if your new fitbit works out.
Best Answer10-22-2018 11:06
10-22-2018 11:06
No they gave me no issues at all. We walked through the steps to attempt to turn it on and also a factory reset. They told me I didn’t have to send back the defective one. I am to take the defective one to a battery recycling center once I get my new one. I expected more of an issue from them and was presently surprised. I don’t know if it is because they pulled my order from when I bought it less than a month ago. Wish I was more help.
Best Answer11-26-2018 06:07
11-26-2018 06:07
I have the same issue too. Versa will not reset at all. It is dead
Best Answer09-08-2019 18:50
09-08-2019 18:50
Hi. Factory reset isn’t helping. What can I do?
Best Answer10-25-2019 18:52
10-25-2019 18:52
I am also having this issue. Fitbit, can you help me? I have tried resetting and it is not working.
Best Answer10-25-2019 20:15
10-25-2019 20:15
Hi. I´m with the same problem. What should I do?
Best Answer10-25-2019 23:59
10-25-2019 23:59
