05-25-2019 06:57
05-25-2019 06:57
Hi,
I have a versa, it’s stopped charging, won’t turn on. When I try to charge it it gets hot. I’ve tried swapping chargers and USB’s and cleaning the bits inside but it still won’t turn on
thanks
05-25-2019 17:49
05-25-2019 17:49
@Fallon83 Please do not attempt to charge it if it gets hot. I am flagging your post for Customer Support assistance as I am afraid this might be a faulty unit.
Best Answer05-25-2019 17:49
05-25-2019 17:49
08:25
13:15
05-26-2019
08:25
13:15
A warm welcome to the Community @Fallon83 and @Marrrmaduke thanks for the input.
I appreciate all the efforts in trying to fix this battery issue. Upon checking with our support team, I was told that you have already contacted them. I know they will be glad to help you out and provide you a solution, just keep an eye on your inbox for further assistance.
In the meantime, let me know if you need anything else. ![]()
09-11-2019 10:52
09-11-2019 10:52
Hello mine is doing the same thing. Won’t turn on, the screen blinks a blank screen. Like it’s turning on but it won’t. Then when I charge it I did notice it’s started getting hot too. So I stopped charging it.
