06-30-2019 15:01 - last edited on 06-30-2019 15:51 by LiliyaFitbit
Hi! My Fitbit versa is just over a year old. The other day my Fitbit was showing low battery. I put it on my charger and the screen lit up showing it was charging. However, I went to check on it later. I took it off the charger and it was very warm. The screen is black and is not turning on. I tried holding in the buttons and looked up some tips but nothing seems to work. My Fitbit is in good condition. Any suggestions?
06-30-2019 15:50
06-30-2019 15:50
Welcome to the Fitbit Community @JodyK212 .
I appreciate your participation in the Forums and sharing that your Fitbit Versa doesn't turn on and gets hot when you try to charge it. Thank you for your efforts to resolve this. I've gone ahead and escalated your case to our Support team, for them to assist you further and provide a solution. Please keep an eye on your inbox for further instructions.
Best Answer06-03-2020 03:40
06-03-2020 03:40
The same thing just happened with my Versa...HELP!!! I woke up this am and it was warm and now it will not turn on or charge at all!!!
Best Answer06-08-2020 18:42
06-08-2020 18:42
Welcome to the Fitbit Community, @BarbaraS21.
Thank you for joining the thread and sharing that you're experiencing the same issue with your watch. I appreciate your efforts and the additional details. I understand how you are feeling and I am here to help. I've sent your information to the Customer Support team so they can get in touch with you and provide further assistance. You should be getting a reply soon.
Let me know if you have any questions.
Best Answer06-08-2020 19:39
06-08-2020 19:39
I was wearing my Fitbit, battery charge was at medium, ladt synced 5 hours ago. But just now when I tried to check my steps my fitbit was dead. I tried charging but that didn't work. Its just a black screen, holding in the button or attaching to charger does nothing. Please help!!
Best Answer06-08-2020 21:59
06-08-2020 21:59
This has just happened to me also! ☹️
Best Answer06-08-2020 23:33
06-08-2020 23:33
Same problem
Best Answer06-09-2020 02:13
06-09-2020 02:13
Very similar to the issues Jody had, my verse will not turn on or reset. Nor does it accept a charge and if I tried charging, its very warm to the touch. Warm enough to where I will not leave it charging for fear it may rupture. Researched how to rest by holding a series of buttons but nothing has worked. I no longer have a receipt but purchased at the Exchange store on an AF base. What other options are available to me in solving this issue?
