12-24-2019
02:06
09:16
AlejandraFitbit
12-24-2019
02:06
09:16
AlejandraFitbit
I shutdown my Fitbit Versa and when I tried to open it it didn’t work. So I tried the charger and that failed so does anyone know what to do.
Moderator edit: subject and content
12-24-2019 08:23
12-24-2019 08:23
Try a Restart and do it several times if necessary.
Best Answer12-25-2019 09:16
12-25-2019 09:16
Welcome to the Forums, @TDAYT and @SunsetRunner, thanks for the input.
I appreciate all the efforts in trying to fix this turning on issue. I was able to see here that our friend @SunsetRunner provided some instructions in order to fix this problem. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Now, if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. 🙂
Best Answer12-25-2019 09:25
12-25-2019 09:25
Just took mine out of the box. Turned on now is dead. Nothing. Anyone?
Best Answer12-29-2019 10:17
12-29-2019 10:17
Hey @Katgem, welcome to the Community.
I would like to know if you keep having issues with your watch? If so, I recommend following the instructions provided by our friend @SunsetRunner in his previous post.
Keep me updated. 😉
