07-01-2020
03:28
08:06
07-01-2020
03:28
08:06
Heart rate was very high then it died completely - second versa I've had now - not impressed !
the first done this almost a year to the date I bought it , i was sent a replacement but now this has done exactly the same thing - no life on screen at all , tried a reset but nothing .
Any ideas ?
Hi there @Lyndy-lou, welcome to the Community Forums. I'm sorry to hear about your Versa's recent behavior. Thanks for taking the time to troubleshoot it prior to contacting us, I'll be glad to help you.
As per the description of your post it seems that the battery of your Fitbit may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc. You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Hope the steps suggested above work, let me know if you need further assistance.
Hi there @Lyndy-lou, thanks for the update. I appreciate you've taken the time to follow the tips and recommendations I provided. Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you as soon as possible since our support options are limited and wait times are longer than usual.
I'll be around if you have any questions present.
