08-19-2020
10:38
14:10
08-19-2020
10:38
14:10
I put my Versa on charge one evening and when I came to put it on I found that it had turned itself off and now will not turn off n at all, just a black screen. It’s only just over 2 years old so not impressed. Any fixes, please help? If it’s junk now going to get an Apple Watch. Had so many problems with Fitbit products, aria scales gone wrong, previous Fitbit Blaze gave up, got replaced under warranty and then the new replacement only lasted 12 months, absolutely fed up of this crap quality!
Hi there @MarcD., welcome to the Community Forums. I'm sorry to hear that your Versa isn't turning on, I understand where your frustration is coming from. I'll be glad to help you with this.
While reading your post I was wondering if your Versa is vibrating when you connect it to the charger? If it's not, it could not be having a good connection with the charger so that's why it's not properly charging neither won't turn on. If you haven't done so yet, I'd recommend trying the following suggestions:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take in consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
I'm looking forward to your response, keep me posted.
