08-21-2020
10:45
10:54
08-21-2020
10:45
10:54
I tried to restart my versa I had for 2 years by doing the three buttons. It turned on twice then shut of again. Now it want turn on at all. Please help!
08-22-2020 10:59 - edited 10-09-2023 08:17
Hi there @KevinJK19, welcome to the Community Forums. Thanks for the details provided in your post about your Versa's screen behavior. I appreciate you've tried to restart it prior to posting here.
While reading your post I was wondering if your Versa vibrates when you connect it to the charger? If it doesn't, please try the recommendations below:
If the above steps don't work, I'd suggest performing a restart by following the steps below:
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Best Answer08-22-2020 10:59 - edited 10-09-2023 08:17
