04-16-2020 18:06
04-16-2020 18:06
My versa has had a blank screen for about 3 days now. I have tried resetting it (logo wont come one the screen at all), holding all 3 buttons for a few minutes, charging, etc. Every once in a while on the charger the screen will light up, but it doesnt do anything. The green lights on the back arent even lighting up. Any help would be appreciated. Getting frustrated.
04-16-2020 18:13
04-16-2020 18:13
I am having a similar issue. Will charge and FitBit logo just stays on screen.
Best Answer04-16-2020 18:14
04-16-2020 18:14
04-16-2020 20:31
04-16-2020 20:31
Mine has had a black screen for 2 days now...fully charged but NOTHING will respond, my app says it synced 3mi n ago so...I dunno.
04-16-2020 20:35
04-16-2020 20:35
Today mine has done same thing . I have emailed them .current waiting time is 7 days to get a response .😏
04-16-2020 20:37
04-16-2020 20:37
Best Answer04-16-2020 20:41
04-16-2020 20:41
Mine is about 15 months .I would expect this to last longer .. am hoping they will replace our chargers ...
Best Answer04-16-2020 21:21
04-16-2020 21:21
mines doing this too ! it's only 3 months old and swapped my original versa because the battery was shocking..
Best Answer04-16-2020 22:24
04-16-2020 22:24
Mine is also 15 months old. Maybe it the batch. Hard to believe so many have done this suddenly.
04-17-2020 05:01
04-17-2020 05:01
Best Answer04-17-2020 05:31
04-17-2020 05:31
Mine is doing something similar. Starting two days ago the screen is blank - won't turn on off the charging cradle (tried all button combos even for reset). On the cradle, it will sometimes show the logo and sometimes turn on. When it is on, I can get it to sync. It reports full battery - but turns off immediately when I remove it from the cradle.
04-17-2020 05:52
04-17-2020 05:52
Sounds like we are all having an issue. My husbands Versa turned off 2 days ago and won't come back. Now mine has done the same this morning. I guess tech support isn't deemed "necessary" by FitBit.
04-17-2020 06:39
04-17-2020 06:39
on Monday, mine wasn’t syncing properly so I did a factory reset.
Since then, the watch is dead. I bought it in Oct 2018.
I have email to Fitbit support and they sent me Amazon link and told me to buy another one at my own cost, because the device is out of warranty. Shocking!
It is apparent that the device/ software is faulty. How can so many people experiencing the same black screen issue in the same week 🤬 and Fitbit is not taking any responsibility for it.
@AlessFitbit
04-17-2020 09:41
04-17-2020 09:41
Have you tried pressing all 3 buttons? It's worked for me !!
Best Answer04-17-2020 09:45
04-17-2020 09:45
Best Answer04-17-2020 10:38
04-17-2020 10:38
Same issues here. It took me a while but I finally got through to the chat support and after going through all the troubleshooting steps that I had already done once again (double checking charger alignment, cleaning charge ports, using a different outlet, factory resetting) nothing would display on the Versa at all. Since it is out of warranty I appear to be out of luck. They emailed me a link for 25% a new device. Sad face. 😞
