02-11-2019
10:19
06:49
MarcoGFitbit
02-11-2019
10:19
06:49
MarcoGFitbit
I really love all the things my Versa is CAPABLE of doing. I just wish it would do them dependably. Sometimes I get notifications, sometimes I don't. I have to restart my phone at least once in a 24 hour cycle to get it to sync properly. Today, after 4 weeks of properly autorecognizing my work-outs as exercise, it decided not to recognize 35 minutes of aerobic workout, although it did credit me with activity time. And when I entered it under "log previous" it took away my activity time.
I've tried restarting; I've tried shutting down the auto-recognize feature, turning everything off, turning everything on, shutting down the phone. I am not inclined to reset the watch and lose a month of results. Coming from the Pebble world, I am very disappointed. Why can't it just do what it is supposed to?
The phone is a Samsung A5 (2017), which is not on the compatibility list - but that doesn't explain why things work one day, and not the next. It does account for the sync issue.
Any insights would be appreciated. I have searched and seen that others are having similar sorts of issues. Will Fitbit consider patching the problems, since it seems more common than it should be?
Moderator Edit: Clarified Subject + Removed Personal Information.
Hello @Mimo_Mimo, I hope you're doing well, thanks for taking the time to share your experience with us. ![]()
I appreciate your participation in the Forums and for letting us know you've already tried to troubleshoot these issues. Please note that when using a mobile device that's not on the list of compatible devices, it's possible that some features will not work as intended. Nevertheless, my best recommendation at this moment is to perform a factory reset on your Versa. A factory reset will remove all your installed apps and settings and the information that hasn't been synced yet, which is why I would like to ask you to sync your Versa before performing this operation.
To factory reset your Versa, go to the Settings App on your watch > About > Factory Reset. Note that you will need to set up your Versa as a new device after the process has finished:
I hope this can be helpful, give it a try and let us know the outcome.
