02-08-2022 08:09
02-08-2022 08:09
Hi,
I use Versa2 for last few months. I am able to track the walking exercise by enabling (A-GPS) from paired phone and that is able to track the distance (though that is also error prone and the distance is not accurate sometime, but it can at least track the same).
But if I use the exercise for other activities like Biking, then it does not even track the distance and just says 0Km. In same scenario if I just switch to walk, it starts tracking.
It appears something is wrong with other activity tracker.
Thanks,
Sachin
02-08-2022 23:03
02-08-2022 23:03
@sachinpatki - did you restart the watch and check the settings for outside biking when you enable it before starting.
02-09-2022 08:19
02-09-2022 08:19
Is Exercise -> biking by default expected to be outside/outdoor? If so I tried the same.
Also I suppose we do not require to restart the watch while switching between activities like walking or biking
Best Answer02-09-2022 08:25
02-09-2022 08:25
@sachinpatki - a watch start isn't normally required but may have fixed the issue.
I misread the switch to walk. Was possibly thinking indoor biking won't measure distance.
02-09-2022 08:41
02-09-2022 08:41
Both activities are outdoor. Let me restart the watch and try again.
Meanwhile, I assume exercise-> bike is expected to be outdoor. Correct?
Best Answer02-09-2022 08:46 - edited 02-09-2022 08:46
@sachinpatki - yes but it may auto start or be started manually, there are some differences.
Probably best to check the manual.
02-10-2022 06:16
02-10-2022 06:16
@sachinpatki I apologize if I am misreading your post. Are you using the Bike shortcut on the Versa 2 with connected GPS or the auto recognition feature (SmartTrack). Smart Track doesn't measure bike distance. The Bike shortcut will give you your GPS distance in the exercise details. It doesn't add that distance to your daily total distance. Daily total distance only comes from step based activities, not biking or swimming.
Laurie | Maryland
08-01-2022 03:44
08-01-2022 03:44
Thanks for your response. And sorry to not get back immediately
On Versa 2, there is an option Exercise => <various modes of exercise including walk, bike, swim, etc> I am trying Bike in this. I am not sure if that maps to "Bike shortcut" OR auto recognition feature (SmartTrack).
Also I am not counting on this to add into my daily steps, of course not. If I am on bike (bicycle) it should not count that as walked steps anyways.
But what I was expecting is if I explicitly select Exercise => Bike and then ride my bicycle, it should tell me how many kilometers I travelled. It says 0 Km always.
Do let me know if thats not expected to work
01-28-2023 22:59
01-28-2023 22:59
I tried updating the latest SW on Versa2 and do the same steps to track Biking activity inside Exercise. But that still shows 0km. It appears this tracking feature doesn't work.
Has anyone tried using this and seen it working?
Best Answer01-28-2023 23:56
01-28-2023 23:56
Hi @sachinpatki - are you taking the phone with you when you go biking?
And did you select connected GPS before starting the ride, by clicking the gear icon when you have selected bike as the exercise?
