01-16-2021 09:44
01-16-2021 09:44
Anyone else have their Versa2 cut off and not work again. This thing is less than a year old and was at 60% battery... didn't drop it or anything crazy. I was literally driving to get groceries it vibrated and showed the fitbit logo then hasn't turned on since.
Best Answer01-16-2021 10:35
01-16-2021 10:35
It probably got corrupted somehow.
Try holding the left button for 10 seconds and see if it vibrates or the logo appears.
Best Answer01-16-2021 10:40
01-16-2021 10:40
Mine just stopped yesterday after upgrade, tried everything but nothing respnding
Best Answer01-16-2021 10:45
01-16-2021 10:45
@Dianetu, @SallyHarder Probably best to contact Fitbit Support directly. They may be able to help you.
Best Answer01-16-2021 10:52
01-16-2021 10:52
