06-07-2022
06:27
17:58
06-07-2022
06:27
17:58
Hi All ..I changed my clock face and since then my watch is showing wrong time. How to fix it? Tried everything. Changed time zone and location. No luck!
06-07-2022 07:58
06-07-2022 07:58
Did you try using the old clock face to see if that is the issue?
06-07-2022 23:01 - edited 06-08-2022 09:39
Hi @Deepa21 - sometimes a simple sync isn't enough. Often a watch restart and sync does the trick, and sometimes even a phone restart helps.
On Android even clearing the storage cache and force stopping it can help set the time right.
When you login again go to the phone home screen without closing the App, click on the sync popup, it will help with the syncing.
